red/white tails that arent upside down?
you will have an issue with the placing of the bulbs. The brake bulbs will not fit on to the other sockets and vise versa. so when you brake, it will be clean and your reverse and blinkers will be red. You could modify the fittings to be able to swap the bulbs. DO NOT cut the wires and try to keep the housings in the same place. The housings are meant for different bulbs in the break and blinkers/reverse
you understand?
you understand?
yeah i wasnt gonna try that....maybe cut the plastic out and glue it in the other end. that way i could use the correct bulb holder thingy in the correct spot...or somthing...but i have to find all clear ones first
