D16Y8, Vtec not working, where do I start???
So far I have disconnected it to see if the ECU is even reading it, and the check engine light comes on, so I know it is reading it.
I ran a toggle switch right to it and would hit the switch at 5000, but nothing.
I checked the oil and it was low so I put some in but still no luck. Should I reset the ECU after toping off the oil?
Anything eels I should be checking? What can make this happen?
Cburke.industries.
Custom suspension bars, metal fabrication.
Cburke.industries.
1. Has the motor been taken apart ?
2. Is the vehicle throwing any codes at all ?
1. Check oil pressure.
2. Check to see if solenoid is functioning properly.
3. Check the vtec system per the honda helms manual.
My wife was driving it and said the check light came on. I am used to the EF were you can see the light on the ECU tell you the code. How can I read the code on this car?
Cburke.industries.
Cburke.industries.
https://www.tamparacing.com/forums/h...king-post.html
Has a mil code checking tutorial link.
