b16 oil pressure problem/question
Old Jan 25, 2008 | 01:08 PM
amimaxima's Avatar
Alright I went through 3 different methods of primming the motor and the final conclusion was the oil pump is not good. So I ordered a new oil pump oil pump o-ring oil pick up gasket and front main seal. I took everything apart and there weren't any definitive signs of what would be the culprit. I installed all the new parts and within 90 seconds of primming the motor I had oil pressure. So everything is up and running, Just have to start the break in process.
Old Jan 25, 2008 | 01:13 PM
DemonCivic's Avatar
good deal, glad you got your problem worked out. g/l
Old Jan 25, 2008 | 07:20 PM
civicized's Avatar
You took the oil pump apart and there were no signs of anything wrong? Something is missing from this picture.
Old Jan 25, 2008 | 08:02 PM
amimaxima's Avatar
I took the oil pump apart and there was nothing wrong with it. I don't know exactly why I wasn't getting oil pressure before but now that I put the new pump in there is thing is fine
