decidin on a swap
gsr..why? the b16 is pretty expensive for the performance u get..its small displacement = low tq.
the ls..well..its missing vtec so it has the lower end grunt..but no top end
the type r is just way to expensive for what u get..
so the best swap would be the gsr..
or if u want ..u can build and lsvtec..not hard but make sure u dont cut corners..this could cost u as much or more then a gsr swap depending on what u want.
this swap would be the best price/performance normally since u have more tq then a gsr with the same top end power..but its also a little harder to do correctly..
so for problem free reliablity a stock gsr would be a nice way to go..but if u want all motor..then build a lsvtec or b20vtec..using oem parts can net u some great hp..or go all out and build a nasty ass na motor.. its up to what u want to spend really and what kind of power u want..
yeh i had been back and forth between b16 and possibly h22...my car is an exact copy of an Si only thing missin is the motor and rear discs...but hey will see...now i got the teg...might just build that ls and keep ek for DD
Girls who drive hondas are HOT! Girls who WORK on hondas are HOTTER!
R.I.P Kevin "Slo_Si" Gonzalez - 6/21/86 - 9/13/06
R.I.P Pablo "Fathead" Garcia - 9/28/85 - 9/5/07
