h23 vs h22
Old Dec 4, 2007 | 08:10 PM
brownguy06's Avatar
Big Nate
Question h23 vs h22
i just recently got a stock h23 for my 92 prelude si. and i was wondering is there any way to build the h23 to get as much horspower out of it. or should i just go with a h22. i heard once the h22 is built the right way its a beast. any advice would help.
Old Dec 4, 2007 | 08:20 PM
SmokinS13SR20's Avatar
That ginger...
Rule of thumb: If anyhtign is built the right way it can be beast.
A sleeved, low comp H22 on 20 lbs of boost would be nasty, but you're tlaking $money$
It is very possible to get the same power of an H22 from an H23, but would I? I wouldn't...
Old Dec 4, 2007 | 08:23 PM
sleepinsol's Avatar
starting over
and y wouldnt you? ^^^ im curious to know as well.
Old Dec 4, 2007 | 08:27 PM
Jspec94LUDE's Avatar
ROLLIN UP STANKY!!!
all motor the h22 is cool for boost h23 all day long or just spray a big shot on the h23 with the proper internals of course much easier to build than h22 cause of h22's crappy frm sleeves
Old Dec 4, 2007 | 08:37 PM
That ginger...
Meh, he said "if it's built right"
Old Dec 4, 2007 | 08:44 PM
That ginger...
Because...
H22A = 200hp @ 7000 - 156ft/lbs **STOCK**
H23 = Peak HP 134.1 Peak TQ 135.2 **BOLT-ONS**
...that's why...
Old Dec 4, 2007 | 09:05 PM
brownguy06's Avatar
Big Nate
so from what i see here the h22 is the better motor then the h23 but going back to the thin sleeve on the h22 can i use the h23 block with the h22 head would that work?
Old Dec 5, 2007 | 06:09 AM
ekhatchboy's Avatar
Redrocket part 2
heh FRM sleeves are strong as fuck...hence why porsche uses them. You have to get a set of mahle pistons or something with a coating for the sleeves because forged steel is too hard of a surface and will damage the sleeves. but as far as boost goes you can put quite a bit of boost to the frm sleeves wth mahle pistons. just don do it on stock pistons because the cast metal that the h-series pistons are made of are not very strong. g/l with the build.
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Dec 5, 2007 | 07:31 AM
Ludeworx's Avatar
Sponsored.
The FRM sleeve is a "soft" metal it was designed to shed weight and be used in conjunction with the poly coating on the piston skirt. hence the reason why people sleeve the H22....You'd be much happier with the H22 over the H23 and don't get any silly ideas about swapping the head.
Old Dec 5, 2007 | 07:46 AM
brownguy06's Avatar
Big Nate
thanks for the advice everyone. now i have to find a h22
