Mid 200's on all motor!! ANybody ? what internals do i need?
You need to search some more because there are 1000's of threads of stuff like this all over the internet.
Honda Tuning mag just did a article for 6 months about endyne's 250 whp build.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
K is the Way.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
Thanks for the input everyone. I'll throw the rep around!! Im doing my research and seeing a trend. It would almost be smarter to just go b20vtec, it would probobly be more cost effective too. I dont have nothing against K series but Im gonna stick with da B!!
I found this on honda forum but not mid 200's
My oem true 81mm oem ITR setup
Motor:
'00 JDM ITR stock short block
'00 ITR head with Portflow competition head-work (full race port, full radius valve job, fully polished combustion chambers, head milled .010)
Buddy Club flat faced valves
Buddy Club springs and retainers
Buddy Club spec IV cams and gears
Buddy Club thin high-compression head-gasket
Comptech Fully ported ITR Intake manifold
Hondata insulated Intake manifold gasket
Max Bore tapered bore ITR throttle body (70mm-65mm)
OBD2 prelude 290cc injectors
Benen High-flow fuel rail
SX fuel pressure regulator
Earl's high-flow fuel filter w/ custom steel braided fuel lines
Hytech 1.8L production header
Modified J's racing test pipe
Buddy Club Spec II cat back
CTR N1 racing pulley
Mugen Baffled oil pan
Buddy Club grounding kit.
NGK spark plug wires
Transmission
'98 JDM ITR spec Spoon tranny
ATS 4.9 final drive
Kazz 1.5 way LSD
Exedy ultralight flywheel
Exedy 3-puck thin race clutch
Motor:
Transmission
ATS 4.9 final drive
Kazz 1.5 way LSD
