cylinder honing
Old Oct 30, 2007 | 06:19 PM
sleepinsol's Avatar
starting over
good call there ^^^ .
Old Oct 30, 2007 | 07:22 PM
KJ's Avatar
KJ
bored at work
Get the finest grit they have available. I think I use something like a 360 grit and it has worked good on quite a few honda and BMW engines.
Old Oct 30, 2007 | 08:18 PM
jlude90's Avatar
aspiring luder
i meant as far as abrasive material, the site i listed has silicone carbide, aluminum oxide, boron carbide, tungsten carbide, 25/75 and 40/60 zirconia/alumina, and levigated alumina from 20 all the way up to 800 grit
i'm assuming we don't really need this high end stuff, i was wondering where y'all got yours
Old Oct 31, 2007 | 08:47 AM
MightyMaxGS-T's Avatar
where you at? i got a hone you can use, i just finished honing a block, only used it once. it'll clean up the cylinders so you can seat new rings properly in it. its better than a bead hone, its a spring hone with adjustable tension and stuff, if ur interested holla at me....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Oct 31, 2007 | 09:44 AM
flashmatrix's Avatar
Chillin in the GS3
Originally Posted by MightyMaxGS-T
its an 84mm because its a b20...napa and discount auto have hones for like $25.....matter of fact i got one u can use.....
no its an 81 mm.
