cylinder honing
Old Oct 29, 2007 | 05:16 PM
jlude90's Avatar
aspiring luder
Default cylinder honing
my girlfriend just pulled apart her B20a, and i was talking to a friend of mine and he was saying to give it a bead hone while the pistons were out
so, i think its an 81mm bore, but i'm not sure where to get one, the only place i found has an 83mm bead attachment, but had like 6 different abrasives on them, i'm pretty lost here, anyone shed some light on this?
this is all i could find
GB and GBD from Brush Research Manufacturing
thanks
Old Oct 29, 2007 | 06:52 PM
MightyMaxGS-T's Avatar
its an 84mm because its a b20...napa and discount auto have hones for like $25.....matter of fact i got one u can use.....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Oct 29, 2007 | 07:05 PM
sleepinsol's Avatar
starting over
b20a? isnt that out of a prelude?? not sure of the bores between the old prelude motors n the newere b20s. how many miles on the motor? when i put new pistons in my ls vtec all i did was deglaze the cylinder walls with some fine sand paper. it had 107k on the motor.
Old Oct 29, 2007 | 07:17 PM
mtber's Avatar
Some new OEM (factory honda) rings would be a good idea too.
If the motor was burning oil or smoking & has a lot of wear, I would inspect the cylinders to see if the setup needs to be bored .25 over per the helms manual specifications.
Old Oct 29, 2007 | 07:38 PM
sleepinsol's Avatar
starting over
couldnt the oil burning come from bad valve guide seals too?
Old Oct 29, 2007 | 08:27 PM
mtber's Avatar
Bad Valve Stem Seals ?
Yes
Old Oct 29, 2007 | 08:57 PM
sleepinsol's Avatar
starting over
yea that lol. just makin sure.
Old Oct 30, 2007 | 04:15 AM
KJ's Avatar
KJ
bored at work
Yeah use the 83mm hone. I've used an 89mm ball hone on an 81mm setup and that worked ok too.
Just remember to oil the hone with 30wt oil and move quickly. Don't stay in a cylinder for more than 10 seconds. After 10 seconds remove the hone and check the finish on the walls. If it is good then move to the next cylinder.
Old Oct 30, 2007 | 05:10 PM
jlude90's Avatar
aspiring luder
its a JDM B20a out of a 3g prelude
she got the motor in and is rebuilding it, new rings, new seals, all that good shiz
complete rebuild, but as we have never had it running, i'l burning is unknown, but everything looks good in it on visual inspection
and is that a good hone?
what abrasive?
or what do y'all use, or is it really necessary to even do it at all
Old Oct 30, 2007 | 05:16 PM
Rambothemighty1's Avatar
Thanks for the advice guys, I'll keep looking around.
I would like to do the bead hone to the cylinder walls even if it's not 100% necessary, I would rather be safe than sorry.
