alternator ground wire
yeah it was just some random person thinking they knew what that wire was. So how would i go about testing the alternator to see if it is putting out to many amps or should i just replace it
Ok so i replaced the alternator and all is good, now here's my next question, the stock D series alternator is a 70Amp and uses a 80AmP battery fuse. The B18C uses a 90Amp alternator, but do I have to upgrade my battery fuse to a 100Amp? What Battery Fuse Amperage do GSR's use?
have the other one tested at autozone or did you already?just keep it at 80
i love AUTOZONE
i love AUTOZONE
Instant fuse blowing means the wire was a hot wire
instead of a ground wire.
If replacing Alt solved the problem......good idea.-Bob
