alternator ground wire
Old Oct 21, 2007 | 11:43 AM
OMGVTEC's Avatar
Retired Moderαtor
Default alternator charge wire
it seems that my alternator ground wire (the one that goes over the stud on the alternator) seems to be getting real hot, as to where the bolt is turning red and frying off, thus making my car run on battery power.
Does anyone know what this would be getting that hot, should i replace the alternator?
Old Oct 21, 2007 | 04:16 PM
Fast420A's Avatar
SRT-4
I would.
2004 Flame Red Dodge SRT-4 - 1 or 2 mods
2007 Bright Silver Metallic Dodge Nitro - Stock
Old Oct 22, 2007 | 12:21 AM
Test the alternator for free at Autozone, first.
Check to be sure both ends of the ground wire are clean and making good contact.
Put on a bigger diameter wire, or run two wires of the same diameter, and be sure both ends are clean and making good contact.-Bob
Old Oct 22, 2007 | 10:12 AM
OMGVTEC's Avatar
Retired Moderαtor
I can see the ground wire on the top of the alternator but the stud got so hot and crispy that it broke off, so i pushed the ground in the tiny space around the stud, then when i connected my neg battery connector, the battery fuse poped.
Old Oct 22, 2007 | 10:16 AM
Hybrid_Ej1's Avatar
5th ej1 one in the making
it happened it to me the nut on the ground wire would glow red then a week later my alternator went and i replaced it....
EJ Crew Member #2
Old Oct 22, 2007 | 10:19 AM
OMGVTEC's Avatar
Retired Moderαtor
whew, at least i know now that im not the only one
Old Oct 22, 2007 | 11:31 AM
rangcrx's Avatar
engine building &best
What Ground Wire What The Hell You Talking About
i love AUTOZONE
Old Oct 22, 2007 | 11:39 AM
rangcrx's Avatar
who the hell told you that was a ground wire PLEASE DO NOT TRY AND HOOK ANYTHING GROUND TO THAT CHARGE WIRE!!!if you are talking about the thick white wire
i love AUTOZONE
Old Oct 22, 2007 | 01:22 PM
OMGVTEC's Avatar
Retired Moderαtor
Yes I circled the bolt/stud that got hot, so you think it could be a bad voltage regulator in the alternator?
Old Oct 22, 2007 | 01:25 PM
rangcrx's Avatar
WHO THE HELL TOLD YOu THAT WAS A neg WIRE?THAT IS THE CHARGE WIRE it runs right accross to your fuse box next to your battery...if it is getting hot then either your alt is putting out to many amps and arking..or you motor is getting to hot..
i love AUTOZONE
