Grinds when shifts into reverse
Old Apr 25, 2007 | 10:17 AM
MAYMAY's Avatar
Exclamation Grinds when shifts into reverse
it is a manual tranny for eg
this happened before i swapped the tranny and
happens to the newer tranny too
it grinds when i shift into the reverse gear...
but there is no grinds from first to fifth...
and i always shift into the reverse gear
when car is standing still....
anyone knows why ?
thanks
Old Apr 25, 2007 | 10:22 AM
envee's Avatar
Green with Envy
clutch is not fully separating from the flywheel? maybe bad master cylinder? not enough pressure in lines? pressure plate failing? weird occurrence since reverse has no syncro.
http://www.cardomain.com/ride/2931273
'06 Mazdaspeed 6
L3-VDT
'02 S2000... Sold
F20c
'93 Civic dx... Sold
B18C1
'95 4dr. GSR... Sold
B18C1 Supercharged
'95 LS... Sold
Originally Posted by shamoo
I have no problems punching a 10 year old in the face if they dented my car with intent.
Old Apr 25, 2007 | 10:53 AM
MAYMAY's Avatar
not sure about the master cylinder.but its got a new slave cylinder
and pressure plate..i have no clue yet...until maybe tear it apart and see...
Old Apr 25, 2007 | 11:18 AM
EGKID's Avatar
put it in second gear then reverse, problem fixed
Ricky
Old Apr 25, 2007 | 11:44 AM
Todd's90's Avatar
0711, USMC
+1, I have been doing this for the past 5-6 years between 2 different cars. putting it in 2nd first will help line up the reverse gear better.
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 25, 2007 | 11:55 AM
MAYMAY's Avatar
ok..i will remember that..
thanks guys....
Old Apr 25, 2007 | 02:54 PM
kumar.'s Avatar
wrd.
ya deff. ive been doing that.. putting it into first or second and then putting it into reverse.. works like a charm.
"Success is 99% failure" -Soichiro Honda
Old Apr 25, 2007 | 03:24 PM
kaluwa's Avatar
My reverse does that too. The second then reverse trick works once in a while, but sometimes it will still grind even if I go into second gear first.
Originally Posted by steezyteg
ok guy your the idiot.
Old Apr 25, 2007 | 03:33 PM
EGKID's Avatar
When its in neutral let go of the clutch then put it in second and reverse see if that helps
Ricky
Old Apr 25, 2007 | 03:40 PM
My Honda Is Slow's Avatar
No really,....it is
yeah i do the first to reverse, have been for many years on many different cars. second to first works just as well.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
