please help!! brakes..
Old Apr 17, 2007 | 02:26 PM
  #21 (permalink)
PbH's Avatar
PbH
the thing with rear break upgrade is you won't feel a huge diference because cars are desing with a 70/30 brake split. Where the front does more work than the back
Old Apr 19, 2007 | 05:53 AM
  #22 (permalink)
madmanmaigret's Avatar
mad like crazy not angry
look what honda made stock with those sized brakes (my guess is the si) so use a si prop. valve and master cylinder and you should be fine.
I AM THE MADMAN
Old Apr 19, 2007 | 06:40 AM
  #23 (permalink)
dscivicdx's Avatar
TR Balla Donor Supreme
Originally Posted by nolexforever
my bad, after researching more:
integra LS brake MC and brake booster are completely bolt-in.
GSR and ITR brake MC and brake booster are not bolt-in. brake lines are differnt size and need to be rebent as well.
and if i'm wrong again, my bad.
as long as you get the ls non-abs master cylinder. make sure you check out the holes to make sure they are in the same position as your stock mc. or you can also just get the mc from a 91 civic ex sedan with 4 wheel disc's and it will work with your stock booster. its a 15/16ths mc just like the teg rs/ls.
Old Apr 19, 2007 | 08:11 AM
  #24 (permalink)
Old Renegade's Avatar
Cool Runnings
that^ will be harder to find than that of a teg.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
