LS/Vtec Build
Old Feb 27, 2007 | 06:21 PM
EGKID's Avatar
How To Measure Piston Ring Gap
1. Spray WD40 on the cylinders
2. Fit the piston ring into the cylinder
3. Push it down about 2 inches using an upside down piston
4. Use feeler gauges to measure the gap between the piston ring
5. Push the piston rings down about 5 inches and measure again
6. Repeat for all piston rings and cylinders
Clearances
Top ring - .20mm - .35mm (.008" - .014")
2nd ring - .40mm - .55mm (.016" - .022")
Oil ring - .20mm - .50mm (.008" - .020")
First I took the piston rings off an LS piston I had laying around I didn't use the P30's because the dome on them kept pushing the rings lop sidded
Pushing one down
Rings Pushed into cylinder
Measuring Gap(I love having small hands)
Ricky
Old Feb 27, 2007 | 06:25 PM
EGKID's Avatar
Originally Posted by rangcrx
very nice setup..man if i did not build so many i would love to post up everyone i build cauxe i take tons of pictures of every build i do just so the person knows what they are getting
This is my first build by myself so I take a lot of pride in it and wanna share it with everyone... It's like having my first baby
Someone just pm'ed me about buying my fat fives on sunday so if I sell them I'm gonna order the bearings
Ricky
Old Feb 27, 2007 | 06:44 PM
EGKID's Avatar
I'm adding a price list on the first post of everything I bought so there will be no more questions of how much it will cost to build an LS/vtec
Ricky
Old Feb 27, 2007 | 08:12 PM
Eluzzionz's Avatar
ull be happy with it ... my lsvtec treated me nicely..even though i only put 7k on it..but every race i won with the exception of the rx7 with the ls1 that ran 11.77 on street tires..forgot the guys name but he pulled 3 cars from like 55-85/90
Old Feb 27, 2007 | 08:20 PM
civicized's Avatar
Thanks for the link, but the Pro1 info was just the usual "jawing" about cams, with no examples of an actual build.
My point to you about cams, is the process done thoughtfully involves choosing a cam and then building a motor to support it. Few would agree that garden variety, OEM parts LS/VTEC is such a build.
As you said, you have your heart set on the cams, but cams are best selected via the head, not the heart. I would like to see your first build succeed, but the little devil on my shoulder also would like you to be my Pro1/P30 test monkey. I already have another test monkey who munched a head with Pro2 cams advanced just 3 degrees.
Just be careful. Guys with a lot of building experience are dealing with the challenge of the pro series cams, namely dealling with cam tuning, clearance and idle issues. It does not appear to be a beginner builder's cam.
Old Feb 27, 2007 | 11:41 PM
rangcrx's Avatar
engine building &best
YOU PAID 90BUCKS FOR ARP ROD BOLTS?????are you sure 99% places they are 38.99 sorry just asking but everything else sounds good
i love AUTOZONE
Old Feb 28, 2007 | 04:42 AM
  #17 (permalink)
EGKID's Avatar
Hmm.. maybe I payed $30 I dont remember it was last year, actually now that I think about it I did pay $30
Ricky
Old Feb 28, 2007 | 05:17 AM
  #18 (permalink)
EGKID's Avatar
Heres someone asking about the Pro2's with my same setup
Honda-Tech.com: All Motor: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance
Heres dyno comaparison against toda C's on a 1.8L and 2.0L engine
More
Honda-Tech.com: All Motor: Mild buld for my b18c5 skunk2 pro1?
Heres a good one
Honda-Tech.com: All Motor: skunk2 pro1's or blox hsl...
Heres the one I was looking for this guy is running Pro2's (read the entire first post at first he ran stock cams then switched to the Pro2's)
Honda-Tech.com: All Motor: All Motor LSVTEC build / dyno
I found more
Honda-Tech.com: All Motor: skunk2 pro1 cams question help
Oh yea and I'm not tunning it, hopefully John Vega will
Ricky
Old Feb 28, 2007 | 07:27 AM
  #19 (permalink)
civicized's Avatar
That's a pile of links that don't tell you anything about what you are trying to do.
Here's the reality, knowing its a big cam, your tuner is going to ask you how much valve clearance you have so he can determine how much he can tune the cams. Are you going to tell him you saw some guys on Honda-Tech who said they were great cams?
He's going to shoot you the "WTF" look and again ask you, as the guy who assembled the motor, exactly what your setup allows him in the way of cam tuning latitude. If you can't tell him, and if he agrees to proceed, it would likely be with the understanding that he may find out exactly how much latitude he has when your engine grenades.
You can't answer a serious question posed by your tuner by giving him links to a bunch of posts where the only thing certain is that forum users there know how to make thumbs up and thumbs down avatars?
I will personally pack my tools and help you degree your cams and clay your engine, if you like. Just message me. I am very curious and the information will be valuable to me for future builds. I cannot, will not install a cam with extreme lift and duration based on incomplete or completely uninformed information. Neither should you. It's not professional. It's not smart.
Old Feb 28, 2007 | 08:35 AM
  #20 (permalink)
Steve C.'s Avatar
hoollaa
Awsome build!!! Moving pretty qiukly!!
