H22A Type S into ef hatch
Im planning on swapping the 97-98 H22A Type S motor into my 90 si hatch and was just wanting to know what kind of modifications would have to be done in order for this motor to fit. As far as supension, frame work, wiring, etc. Any help would be nice. Also the motor puts out 220hp 163lbs of torque. What knid of times should i be looking to get with this setup??
And it's almost 200lbs heavier than a B16. You're gonna have to do a lot of suspension upgrades as well as a rear disk conversion with that kind of extra weight up front.
I cant give you specifics at the moment though...Lemme research it more and I'll try to get back to you.
sport compact put a h22 into a crx ran 14s all motor on drag radials, i dont really think it is worth it, you gonna have to bang the shit out of y ou f/w, cut the tranny mount to relocate it, put in a prelude shifter box. custom axles. bang the shit out the frame so the tranny will clear, run tractions bars or cut the shit out your front crossmember. rewire your harness. im sure there is more to it. search sport compacts website for it,
power wise I dont think its worth it, but if your doing to be different go for it cuz it's not something you see everyday
you could see the same numbers with a supercharged or turboed b-series
Ricky
Ricky
Um no. You really need to pull your head out of your ass and learn something before you talk. All the stuff you are talking is not necessary.
As far as the swap goes, get the hasport kit, it's basicly a drop in process with not that much wiring. Your going to have to run an aftermarket front X member and SLightly modify the rear.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
H series are great swaps, they cost as much as a b16 but make WAY WAY more power.
A h22 Type S, with some good cams, header and some minor tweaking will make more power then a "built" B series vtec motor, hands DOWN.
_Jake D
_Jake D
h22 is not bad bro but does motor r heavy and fast but not too great if i was u i would go b16 or some bseries cuz u going to be spending more money then u think just from dat motor datz my point of view and it also sound like a nice project so good luck!
Btw a FULL h22 swap runs about 1900. In and in the car running under 3k.
_Jake D
_Jake D
