CRX will not run after hitting bump on US19
u check for stupid shit? like the dizzy/wires coming out of alignment/loose? wait, if u have spark, then nm that one....
wouldnt hurt turning the car over once with the rail/injectors off, just to make sure u got gas spraying out (i dont need to go into how OUTRAGEOUSLY DANGEROUS this is, so please be careful)
check all your TB connections? (MAP/TPS/IACV and throttle cable)
it really just sounds like a ground or power came off for the ECU or some really important relay under the hood....
you sure you arent just out of gas?
hahaha... so the real question is: why did the timing jump?
was the belt really loose enough that hitting a bump made it pop off? you know how loose that would have to be? you are very lucky nothing was harmed....
