Starting a new little project!
well im not totally sure... if you can find some cheap itr cams - go for it
but if not... you can go with blox- good brand but pricey
i personally like crower, i have used them in many builds and they have always worked great... and they are not as pricey as blox.
yeah like i stated before... if you want this done right... then you may wanna get a valve train to go with the cams... 9 times outta 10 , you have to upgrade the valve train to go after market with cams
oh and you would wanna get a tune after you do all this work... to prevent timing issues - blown99civicsi does this too!
but like i said before... if you want this done 100 percent right... go with good brands and do it right the first time... in the end... it will save you $$
if you go the cheap route... you may have to rebuild it AGAIN and that would cost more $$
thanks ill do that...do you know anyone who tunes and may help me put it together or somewhere i can get put together i know how to do it but i want to make sure its done by someone who knows exactly what there doing
pm blown99civicsi and tell him that i told you to talk to him... im sure if you buy enough from him... he may hook you up a bit on that tune
, great guy and easy to work with
this is his website in my sig... check it out if youd like...
