Valve size question
If you go +1mm on the valves you need to have the seats changed out and a new valve job. Changing out the seats is pricey sometimes. Also if the bowls are not ported when you go up in valve size you will see no gains and maybe even lose a little due to the increased shrouding. +.5mm can be done on the stock seats but again it is only worth it if the bowls are ported.
Gracie Barra Clearwater
oh ok, thanks for the info KJ, helps me out alot
so in order i would need to:
get a real good port and polish
then get the +1mm or +.05mm seats changed
then get the 5 degree valve job
is this right? and as far as the +1mm oversizing, will this weaken my head and cause it to crack? should i only go .05mm?
Stick with the smaller valves (depending on app) Bigger is not always better
Port, dont polish(a little secret)
NEVER go 5 angles on the vavle job, useless. 3 is all you need. The trick is picking the angles based on the application. Call me and we can discuss further. Matt 941-626-4715
Thats right fools, 2 Prostockers this year
