Need Turbo Advise
Old Aug 14, 2006 | 05:18 PM
DOHC16CRX's Avatar
CARPET GUY
Exclamation Need Turbo Advise
Ok guys this is my first turbo set up and i figured i would go all out with this one.I will tell you alittle about the build to help you understand what i am looking for in power.I have a b18c golden eagle HD sleeved BLOCK thats 84mm.I have cp pistons.9;1 .I am getting kris's peuter rods so the bottom end is good for 800+ all day. The head will be full race port and polish with the valve tran work up.MY GOAL IS 500-600 WHP on daily driven dc2 teg,Now my question mainly is what is the best turbo for 600 hp that spools up at a decent rpm.I here alot about the sc61 but i am not sure on there spool and out put.Also what injector size would be correct for 600 hp.My other main thing i need to know about is what is the best turbo manifold to get to 600+ hp and have a/c.I have everything but the turbo ,manifold and DP.any help with this will get rep points.Please only respond if you know what you are talking about.Thanks alot for this info GUYS !!!.
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Aug 14, 2006 | 07:06 PM
Slo_Si's Avatar
$200 Motor!
Well, obviously a ball bearing turbo would help you spool sooner...if your looking for 600whp i would go with a gt35r....as far as injectors go...get some precision 1000cc injectors, they should be fine...as far as manifold goes...there are plenty of nice a/c compatible manifolds, just dont go with one-fab, they crack, just ask me or alpha....we know from experience.. you can go with neukin, spoolin performance, sfp, and im sure im missing a few others...they all have nice a/c compatible manifolds that will support the power that you are looking for...hope this helps you out some...
- Officially Retired....for now...
Old Aug 15, 2006 | 03:34 AM
Alpha's Avatar
Like Slo_Si said. GT35RLS is your best bet
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Aug 15, 2006 | 04:01 AM
flaco0018's Avatar
sfp is closed ftw
Old Aug 15, 2006 | 04:07 PM
DOHC16CRX's Avatar
CARPET GUY
I will look into that turbo.What does it spool at? thanks for the info guys !!
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Aug 15, 2006 | 04:11 PM
Jap's Avatar
Jap
VTEC Out
AFI A/C compatible RamHorn/dumptube/3" DP , TiAL 44mm , GT35RLS , Precision 1000cc or larger , AEM EMS , Precision 600/750 IC , 2.5/2.75" IC piping , JG Edelbrock or Full Race Intake Manifold , 68/70mm TB , ITR cams
This should get you what your looking for ....
Hondata saves lives
Old Aug 15, 2006 | 08:20 PM
Punkinterviews's Avatar
Chavez Motorsports
Call me when you can so we can discuss some details.
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Aug 15, 2006 | 10:57 PM
Crab Cakes's Avatar
So Lost!
ya what he said
Im The Original Crab!
Old Aug 16, 2006 | 11:21 AM
SloCxHatch's Avatar
No "V-TECH" here!!!
see the turbo in my sig.... that should get you to your goals...
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
Old Aug 16, 2006 | 01:18 PM
BDIX's Avatar
Dick is Huge!
hm.. I didnt think the GT35r would get you those results..
isnt this the turbo Dario is running?
Totalled his shit!@
