a/c only cold while driving, hot when stopped.
Old Aug 3, 2006 | 01:55 PM
trey's Avatar
wo0t
Default a/c only cold while driving, hot when stopped.
the condensor fan comes on, it's got freeon, etc. what could this be? it's getting really aggrivating..
Old Aug 3, 2006 | 01:56 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
idle the car up negro
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Aug 3, 2006 | 02:01 PM
trey's Avatar
wo0t
thats not it, when i hold the gas it gets cold above like 3k, im not turning it up that high... lol
could it be the clutch on the compressor?
Old Aug 3, 2006 | 03:01 PM
00TEGLS's Avatar
You need to check the pressures with some ac gauges. Sounds more like you got air in the system. Make sure your condensor is clean also.
Old Aug 3, 2006 | 03:17 PM
Frankie_P's Avatar
Built.
+1 ....evacuate the system thoroughly and install some new freon...
Old Aug 3, 2006 | 03:30 PM
DemonCivic's Avatar
can be a few things, gauges will tell the tale along with someone that understands what they mean. g/l, let me know if you are in the area and i will check it out for you.
Old Aug 3, 2006 | 04:34 PM
TSX24L's Avatar
Old Aug 3, 2006 | 07:37 PM
Punkinterviews's Avatar
Chavez Motorsports
+1
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Aug 5, 2006 | 05:42 PM
00TEGLS's Avatar
Originally Posted by 1.6L
you do realize that is all refrigerant is, is air. Sounds like the system is under charge or overcharged and or clutch assembly on the compressor.
I have been AC certified and r12 certified by ASE for 8 years r134 and r12 is not just "air". Thats one of the dumbest things I've ever heard. If you have air in your system and have not vacuumed it your ac will NOT work properly. Air will cause the system to freeze up or the drier to get saturated.
Old Aug 5, 2006 | 07:14 PM
b18civ's Avatar
air has moisture, moisture freezes clogging up passage ways. refrigerant needs a dry environment to work properly. I ain't even certified and I know that.
