rear disc conversion on crx
Old Apr 23, 2006 | 09:39 AM
javier vargas's Avatar
\o/argas
Default rear disc conversion on crx
ok i have a 88 honda crx hf and i just recently installed rear disc from another hf crx that was in the junk yard....... now im not sure if it came from a si crx or a integra.....but the problem is that it seems to be to much toe on both sides.....i m not sure what the problem is but before i installed them there was no toe problem....can anyone help......thanks
Old Apr 23, 2006 | 09:53 AM
integraman89's Avatar
lost u already???
you may need to change out your control arms aswell, whats the reason you changed it in the first place? i would probably just go back to what you had in the beginning. https://www.tamparacing.com/forums/h...ion-my-ef.html he just asked a similar question about rear disc swaps, maybe you will find what you are lookin for in there, good luck
Old Apr 23, 2006 | 02:20 PM
KJ's Avatar
KJ
bored at work
Make sure to run your stock crx toe linkage bars. I had the same problem before. Expect to get an alinment also but if you used the linkages that came with the conversion and they were from a teg you won't be able to get it aligned at all. When doing rear disk conversions always reuse the upper and lower control arms and toe linkages that came with your car.
Old Apr 23, 2006 | 03:36 PM
\o/argas
thanks i used all crx parts meaning the lower control arm and the toe linkage bars and im not sure if it integra or crx because it came off a crx hf in the junkyard the old owner of the car must of swapped them out so im not sure which ones they are integra or crx but the reason i did the swap cause i like the look and the passenger side drum was leaking really bad and it was rusted out pretty bad thanks for all the help
Old Apr 23, 2006 | 03:39 PM
KJ's Avatar
KJ
bored at work
put your old linkage arms back on and get an alignment.
Old Apr 24, 2006 | 12:07 PM
\o/argas
thanks everyone
Old Apr 24, 2006 | 07:05 PM
lost u already???
2 thumbs up for KJ
