HELP i just did a rear disc conversion on my ef
ok i just put da rear brakes on my ef and they look towed out.....
did i also have ti use teg lower control arns???
also this was put on my 4dr if that makes a diffrence??
thanks for all the help
Its toe, not tow... and I think you mean camber anyway.. wheels like / \ or \ / ?
Use the upper and lower arms from the same vehicle, either the Teg or the EF, dont mix....
to go along with what he said, you can actually get shims to even out your toe or camber. talk to a tire kingdom or tires plus, they can fix it for you
or you can just use the toe adjusters that honda put there for just that reason
You will need to get it on an alignment rack though to get it right... I suggest you go to Firestone at Westshore mall and ask for Josh and tell him what you need...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
reply to all i work at tire kingdom and have had it on the rack it is adjusted all the way out, no didnt mix arms they are all from my ef..... well i used the teg toe arms but they were longer then the ef ones...... i think i need shorter low control arms?????
thanks for the post
use ALL teg stuff....
