Help water in oil..!!!!!!!!!
Old Apr 21, 2006 | 07:06 PM
rangcrx's Avatar
engine building &best
Originally Posted by freakasis
^^^if that doesnt work you may have the headgasket upside down.
how so?if this was done the holes would not line up
i love AUTOZONE
Old Apr 21, 2006 | 08:21 PM
MazdaMX3Freak's Avatar
Vtack THIS!!!
no i made sure the headgasket was on right, and yes when i took off the head there did get water every where but i thought i cleaned it all up.......and there was smoke when i first turned on the car....what should i do?
-2008.5 Mazdaspeed3 CWP
Old Apr 21, 2006 | 09:55 PM
Vtack THIS!!!
Can Someone Help Plz.....
Old Apr 22, 2006 | 05:27 AM
95gainfla's Avatar
smokes weed...everyday.
Originally Posted by rangcrx
you may just need to drain the oil buy about 3 qts of cheap walmart 5-30 and just pure it tru to try and remove as much as you can
I <3 RooR!!!!!!
Old Apr 22, 2006 | 08:41 AM
Vtack THIS!!!
Old Apr 22, 2006 | 12:21 PM
integraman89's Avatar
lost u already???
like they said, i would drain it all out real good a number of times, once wont really do the trick, after you do it enough times. you need to check it again. there really isnt any hoses that you could get mixed up with cuz there isnt any hoses that transport oil. those are all cooling hoses either way. if you do that flush a number of times and the problem still remains... you have internal issues, and if your head is slightly warped, it woulnt matter if you put a brand new headgasket on there or not, it will still leak. if this all still occurs after all the flushing out you may need to take your head to a shop and have it machined flat. have them check out your sleeves. good luck with this
Old Apr 22, 2006 | 01:01 PM
  #17 (permalink)
-campy-'s Avatar
make sure that there is not water in the head bolt holes cause if there is its almost like getting water in the cylinder the water wont compress and the bolts wont go all the way down and the head wont seat right
Old Apr 22, 2006 | 04:47 PM
  #18 (permalink)
lost u already???
yes that too, clean out all your head stud holes before you intsall the head back on, not only water, but oil as well can get in there and stop your bolts from tightning all the way down.
