Local Place for SLEEVING
Guest
Posts: n/a
Originally Posted by Alpha
...Around Pinellas/Tampa? Who?...
directly.
The shops that I have talked to about sleeving were talking about inserting STOCK sleeves into the block. I know the machine shop I used back with the SOHC said they could install any sleeve I brought them. However they had never installed a performance sleeve in a Honda before.
I didn't mean to say that lots of shops can sleeve like GEM sleeves. I meant they can resleeve a normal stock sleeve into the block.
Cedric @ modern performance WILL NOT SLEEVE A OPEN DECK block. I have been using him for 3+years. Although, He can sleeve any CLOSED deck block. He IS VERY good. He personally does all the work that goes through his shop. Not like some other machine shops that have some idiot ASE certified dipship doing your machining. I have NEVER had an issue with his work.
I have had 2 Golden eagle sleeved blocks sink, Both were some of there early ones. When Benson was the only ones around every block had a sleeve issue. Golden eagle took care of the problem and and i've had 30+ block done by them ( Including my own) and no since problem.
I use GE on every high HP block we build.
Even if someone charges you $100 to sleeve your block, It worth it when it goes wrong.
Spend the money and have it done right.
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
727 344 1800
My Old Honda
My Old Honda
Originally Posted by InsaneCivicSedan
Nowhere in FL sleeves blocks... Anyone who tells you they do, will just send your block out to one of the companies previously mentioned, and charge you a middle man fee... Might as well just do it yourself...
CW Pence & Rebuilders
407 831 8197
Ask for Jeff or Billy.
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
