Not getting power I should ... help?
Old Apr 5, 2006 | 09:00 PM
  #31 (permalink)
2.2L's Avatar
Originally Posted by integra
when i had toda Bs in my crx i had the cam gears at +2 -2 and vtec at 5900 and it ran its best with that i didnt get numbers on it because i just tuned it on a wideband to 14.3a/f
a little lean dont you think?
XXX Motorsports - In House DynoJet
850-457-DYNO
BBmoto Built/Tuned - Where honesty meets quality
Authorized Neptune Dealer/Tuner
Authorized eCtune Tuner
Honda OBD1 CHIPPING SERVICES
8.64 @ 81.22mph
All Motor H23vtec Prelude (stock head)
Old Apr 6, 2006 | 07:39 AM
  #32 (permalink)
sxecrow's Avatar
EG2 CRX
For n/a that's fine.
Old Apr 6, 2006 | 09:52 AM
  #33 (permalink)
2.2L's Avatar
20 bux says you get it to 13:1 - 13:3, it will be faster. Thats the recommended a/f at WOT. 14:7 is good for part throttle. And i like 15:1 - 15:5 at idle.
850-457-DYNO
8.64 @ 81.22mph
Old Apr 6, 2006 | 10:24 AM
  #34 (permalink)
accord95's Avatar
USMC
+1
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Apr 6, 2006 | 10:30 AM
  #35 (permalink)
2.2L's Avatar
just jot this down for the next time you go tuning:
"Always remember to feed the fuel monkey."
850-457-DYNO
8.64 @ 81.22mph
Old Apr 6, 2006 | 10:37 AM
  #36 (permalink)
mtber's Avatar
I agree that 14.3:1 a/f ratio is a bit lean at full load for an n/a motor with decent compression
I would recommend going by what "you like" I would recommend going with what the motor likes
Old Apr 6, 2006 | 10:41 AM
  #37 (permalink)
2.2L's Avatar
LIES!
850-457-DYNO
8.64 @ 81.22mph
Old Apr 6, 2006 | 12:12 PM
  #38 (permalink)
lzylst's Avatar
I wouldn't worry to much about only pulling 17inches of vacuum with those cams. Cams and cam timing can alter vacuum
As far as dyno numbers......... don't fall into the numbers game. Different dynos give different numbers and can be adjusted to whatever you want it to say. Just because someone on HT hit 250 hp with your same setup doesn't mean you will.
Get a damn 94+ dohc vtec distributor cap for starters.
Old Apr 6, 2006 | 03:47 PM
  #39 (permalink)
cxcivic's Avatar
swapin' Hondas since '95
Originally Posted by sxecrow
Ran compression check and did not see loss of pressure on gauge
Came up as: 230/220/220/220 - does this seem low to anyone else?
Yes, needs way more compression. pull the head off and bring it over. ill measure and make sure that the head has been milled. -Neal
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
Old Apr 6, 2006 | 04:01 PM
  #40 (permalink)
accord95's Avatar
USMC
i have 220 across the board with same engine, my head is stock, and his is built, and im putting down the same HP as him, and more torque than him.
___________________
