Stock K24 - 467 whp @ 12.8PSI
Old Mar 18, 2006 | 11:57 AM
  #31 (permalink)
MuTiLaToR's Avatar
Come Get Some!
Ill keep ya posted qitstrn, im hoping for some good numbers @20 psi or so im hoping for 10's btw I ordered a white Si, I heard white cars are faster
Originally Posted by ImprezvSE
It comes down to a safety issue...
If you can't bench press it, don't fuck it.
Other than that to each his or her own.
Old Mar 18, 2006 | 12:06 PM
  #32 (permalink)
ohno's Avatar
Retired
K20 head is the best way to go
k24 bottom end combined with k20 head is a beast
With a proper sized Turbo and Turbo Cams 460whp was made at 15lbs on a k20 STOCK motor with only Air fuel tuning and no ignition advance on 93 octane
Old Mar 18, 2006 | 12:41 PM
  #33 (permalink)
EXtreme7200's Avatar
loves beer!!!!
yea i sure hope it lasts on stock internals...what a sick setup tho damnnnn...close to 500 hp on a stock clutch? sounds like he'll need another one real soon lol
Old Mar 18, 2006 | 01:17 PM
  #34 (permalink)
qitstrn's Avatar
Can you spot me 20 cars?
Well someone said they made 467whp@12.8lbs so at 15lbs you should be at 500whp. Then someone claimed they made 560whp @17lbs. What is the deal?
Old Mar 18, 2006 | 01:38 PM
  #35 (permalink)
ohno's Avatar
Retired
Ron you should know out of all people the thing.
467 @13lbs on a 2.4 block with race gas on a T4 Gt35R
the one I mentioned made 460whp at 15lbs on 93 octane with a 2.0 block on the same T4 Gt35R with no stock timing tables.
I think thats pretty feasible.
Its all turbo sizing and obviously displacement and tuning.
Old Mar 18, 2006 | 01:41 PM
  #36 (permalink)
ohno's Avatar
Retired
Ive never heard of the one of 560whp@17lbs
but obviously if you have a 42R or somethign crazy like that on a 2.4 block itd be possible.
Old Mar 18, 2006 | 01:42 PM
  #37 (permalink)
ohno's Avatar
Retired
5. RSXracerBK04 - 515whp
- Custom Turbo Kit, GT35R
- K-Pro
- 18psi
- Dynojet
- COMPLETELY stock motor
- 5 gallons of c16-3/4 93
- Tuned by St00pid
Old Mar 18, 2006 | 02:00 PM
  #38 (permalink)
qitstrn's Avatar
Well i guess my idea of a safe tune an someone elses are two totally different things. I run my car rich at about 11.7 A/F even on C16. My motor also has 150 dyno passes on it that i can count. 100 at Race Related alone. That motor has yet to blow up and the motor has been down the track about 20 passes. My motor also has the cam gears at zero. These numbers on the K series are impressive. How long will these motors last? Do you know how much timing or the a/f they are running to get the #'s they do?
Old Mar 18, 2006 | 02:29 PM
  #39 (permalink)
ohno's Avatar
Retired
st00pid is a great tuner
he wants to also keep things safe
I believe he tunes for 11.5-12.0 AFs
Timing on the tunes I was referring to were close to stock, which means very low
but I cant compare to the B series since obvioulsy K series has diffent cam angles and differeint timing values at each depending on boost level and how the cam profile for hte angles looks like
how long will the motors last? who knows they are stock motors, you know how that goes.
Old Mar 19, 2006 | 11:26 AM
  #40 (permalink)
TheRedDragon's Avatar
maybe if you are nice 2 alberto he will let you feel the power of the K
ALPHA TUNED
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
