Stock K24 - 467 whp @ 12.8PSI
Ran across this, makes me want to build my K24 and boost it, lol.
Specs: Tuned by St00pid, EG civic with a stock K24A1 CRV bottom end with a K20A2 head.. K-Pro One-Fab top mount manifold GT35R T4 .68A/R One-Fab 26" x 12" x 4" Monster Intercooler Core Tial 44mm WG Tial BOV 750cc injectors Walbro 255 Aeromotive regulator GM 3 bar MAP sensor @ 12.8psi the car made 467whp Quote from st00pid: "Soon after the car went to the track and spun the tires in 1st and second and the the clutch slipped in 4th 5th and 6th.. and ran 11.3 @ 127. The car should be getting a clutch soon and should be hitting 10s then its time for a built motor and more boost. " From the owner: "Motor is completely stock, its a k24a1 from crv, k20a2 complete head with type s cams. Type s transmission w/welded diff Pipes are 2 1/2" from turbo to fmic, and 3" from fmic to throttle body which has a wiggins clamp attached to it Btw, its a stock clutch and flywheel which is slipin already" Video of the car: http://videos.streetfire.net/video/F...CCDAB95E41.htm Another quote from st00pid: "The torque was around 330 if I remember correctly, The problem is that the clutch started slipping on the dyno. So the torque actually read low. Once he gets a clutch in there we can retune. If I can remember correctly the package is around 4800, however the price of the Garret stuff keeps going up, so that number may change." Pretty sick setup. -Mike |
Wow. Killer. I'm buying a CRV.
Good find. I really dont know anything about the K's. Has anyone figured out what the stock blocks can handle on boost? What are the weakest links in them? Are they also hanging sleeves?
Anyhow, that car is ridiculous. |
I think most turbo set-ups run this way, but i cant tell you why. its a secret. (or i dont know)
D-i-r-t-y@@!!!!!!!!!!!!!!!!!!!!
Sickness is the one word that comes to mind.
-Mike |
hahaha sounds exatly like my story with the b18, my clutch keep slippin on the dyno.waitin for a retune. good find
Yea,Did I hear 4th gear tractionless on the street? :lol:...Bad ass hatch,The K-Series swaps seem to be the way to go these days.
wow sumper impressed..
was it on slicks on the track runs? i couldnt tell. |
