GSR in LS
i heard from some ppl that u CAN put GSR rods and GSR pistons in a LS block if u use a GSR crank.....then i called CMS to ask and they said no...so im confused...just want to make sure b4 i buy anything...Thanks TR
CHAVEZ MOTORSPORTS
Great Guys, Great Work, Good Choice
CHAVEZ MOTORSPORTS
As I told you before, you can run a gsr rotating assembly in a ls block...
You asked me if you could run LS rods and pistons with a GSR crank and I said no. I didn't say no to running ALL GSR internals. Sorry for the mistake.....
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
Originally Posted by 95gainfla
i thought it wouldnt work since the gsr is only a 1798cc and the ls is a true 1.8?
does the GSR block have oil squirters? if so, I'd def want to transfer that over as well. If everything else is carried over you've got yourself a LS block with GSR internals...would be pretty cool shit.
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
