450whp sohc...
Originally Posted by NACRX
well its pretty surpising what the single cams are capable of which is reason number 2032 why I love the single cams. My last motor was just a stock vavletrain with minor work done to the head. Port matched the intake manifold to 62 mm. Ran a dry shot converted to wet system. jets equaled 100shot of nitrous. Stock y8 y5 y7 blocks. I went through 4 blocks on this but they hold up. I blew them up just experiementing on them over reving mainly. But could out run anything on the street. Nothing more then a stock single cam motor spraying 100 shot of nitrous. ACT clutch and a flawless crx si tranny. Pretty impressive the d series motors can be. Which is why iam selling my lsvtec build and 1.6 block and a gsr hydro tranny for a d series build.
hint hint. FOR SALE>
Ive seen single cams with a 1in. plate, sc61. Not really all fimliar with terms of the turbo or turbos. But 800cc injectors. Clamied to have 800whp. And it did look and drive like it had 800hp. If you guys would have seen this you would have seen this you would have been in all out AW! So iam saying the single cams are just as good as any dual over head.
hint hint. FOR SALE>Ive seen single cams with a 1in. plate, sc61. Not really all fimliar with terms of the turbo or turbos. But 800cc injectors. Clamied to have 800whp. And it did look and drive like it had 800hp. If you guys would have seen this you would have seen this you would have been in all out AW! So iam saying the single cams are just as good as any dual over head.
i dont think its not uncommon, im just sayin with the info this guy gave me it didnt seem right. 34 psi and hes getting 450whp is all. hp isnt the issue, its the pressure im wondering about.
i dont know why people dont take me seriously....now wheres my crack pipe
Guest
Posts: n/a
It's very possible for an A6 motor to have 450whp. Especially on that much boost.
It is VERY unlikely that:
1.) He was running pump gas
2.) He had a stock head
3.) He is really running that much boost, or making the numbers that he was claiming.
Now, to the guy who was told 800whp with 800cc injectors.... that's not correct. He would need like 1100cc injectors to make 800whp. Much more then 800cc at the least.
It's not uncommon to find a 450whp SOHC motor in the US.
It is uncommon to find one around this area. More so, to find an A6 in this area with 300+whp.
