why wont compressor fit?
Old Jun 14, 2005 | 07:45 PM
SpyderHatch's Avatar
Greddy Mannifolds if you got tehe log style will clear if you got a equal length mannifold you might have an issue but you need a EK compressor on an EK engine the brackets are different alot has to do with year too if you habe a R32 and not a R134a Compressor or EG to EK, Just get a EK compressor for that engine and hope it clears the mannifold Easier than Having someone fab a custom ac.
Old Jun 15, 2005 | 07:55 AM
Greddyboostedcivic's Avatar
H.I.D. has no cure
so if i used an ek compressor with an ek bracket, it should fit? will the bracket bolt up to an eg engine bay?
S14 comin soon...
My Myspace page
http://www.myspace.com/8852084
R.I.P. William Brent Marshall Jr. (4/27/86-3/30/05)
Old Jun 15, 2005 | 09:33 AM
hmm i dont think the bracket will mount an eg bay youll have to mount it and see i wanna say d series to d series it should the only difference in the EKs where the Upper Torsion mounts it was sideways and not vertical. But the lower ac mount should fit. Your issue is the compressor the size of it and how far it hangs down. The EK stuff should fit ! i dont see why not. Ive never had a clearance issue !
