i just got a 1.6 head and....
look if its a 95 vtec head then the spark plugs will be up front on the valve cover. also, you need a vtec distributor so yes you do need a 1.6 dizzy. and as far as the p28 that is not needed. you can run a wire directly to ur ecu. its ghetto vtec but it still works.
