VTEC Questions
Old Apr 27, 2005 | 09:09 AM
CRXcominup's Avatar
Default VTEC Questions
If i do the minme swap my regular head for the vtec head do i have to change dizzy too?
Old Apr 27, 2005 | 09:45 AM
chi town brat's Avatar
! Ne shab'rud'ni !
I did a d16y8 and used my a6 dizzy.
Old Apr 27, 2005 | 10:09 AM
e1000's Avatar
M.O.B.
You can use a different dissy, but you have to mod it to line-up..Correct me if im wrong.
Old Apr 27, 2005 | 04:36 PM
! Ne shab'rud'ni !
just for reference the a6 did not require mods on the y8 and it is obd0.
Old Apr 27, 2005 | 05:23 PM
SiVic's Avatar
y B normal?
The Vtec dizzy will not plug on the A6 wires. The plugs don't match. I think the obd1 dizzy has 1 or 2 more wires than the obd0 dizzy. I used an A6 dizzy on mine.
Old Apr 27, 2005 | 07:33 PM
Hybrid_eg's Avatar
i like the blue ones
The distributor you want to use is dependant on the ECU that you use.
OBD 0 ECU = a6 dist.
OBD 1 ECU = z6 dist.
OBD 2 ECU = y8 dist.
Shut yo ass up nugguh..
ReginaVagina
Old Apr 28, 2005 | 07:51 AM
SEEKERone's Avatar
Trialed for Treason
ok...lets try to clear this all the way up.
The mounting points for the distributor is the same for 88-91 cylinder heads and the 96-00 cylinder heads.
The 92-95 cylinder head distributor mounting point is offset requiring some modification if not using the 92-95 distributor.
As previously mentioned, the distributor you need depends on the ecu you intend to run AND the head you intend to use.
Liar, you couldn't cut me deeper with a knife if you tried
Old Apr 29, 2005 | 09:55 AM
Hybrid_eg's Avatar
You can use the OBD 0 distributor/OBD 1 head/ OBD 0 ECU combo. The head doesn't make that much of a differance. Sure, you'll have to modify the mounting holes on the legs of the dist., but it will still work. The most important part of this is, like I said, the ECU and dist. must be the same OBD era.
ReginaVagina
joshy
Jul 20, 2006 11:16 AM
Cronic
Feb 21, 2005 10:04 AM
Cronic
Sep 25, 2003 05:00 AM
vwbidder
May 24, 2002 03:37 AM
