auto to manual question....
Old Apr 20, 2005 | 05:46 AM
I-NEED-VTEC's Avatar
I have NO vtec!!!
Default auto to manual question....
ok a buddy of mine is doing this and has a problem.he said he cant take the key out w/disconnecting the battery or something.i guess the the park switch might be the prob?i dont know anything about this so im asking you guys.thanks-keith
Old Apr 20, 2005 | 06:06 AM
SpyderHatch's Avatar
yr type of car etc etc
Old Apr 20, 2005 | 12:36 PM
I have NO vtec!!!
oh shit,my bad i think he said its a 90-91 civic 4dr w/si motor.dont really remember met him last night @ advanced on dale mabry.he works there.so any ideas?
Old Apr 21, 2005 | 08:13 AM
accord95's Avatar
USMC
yes, you are correct.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Apr 25, 2005 | 09:00 AM
I have NO vtec!!!
about what?
Old Apr 25, 2005 | 09:02 AM
Pimpgixxer04's Avatar
the park switch??
IF IT HAS TITS OR TIRES YOUR GONNA HAVE PROBLEMS
Old Apr 25, 2005 | 09:09 AM
accord95's Avatar
USMC
Originally Posted by I-NEED-VTEC
about what?
the park switch son, my car is a former auto that was converted to standard. try this, it should help you with the wiring.
Wiring:
Method 1: Now its time to make the car start, first off start by taking the 2 nuts holding the white part on the automatic shifter and plug the 2 wire in that need to go where they belong (brown plug and a long white plug) Then tuck them in somewhere next - put in neutral and hope the car starts, if it does have fun you now have completed the impossible just to correct...
Method 2: I did not remove the a/t control unit, no need to, just extra time to do it. There is also some more wiring that I had to do, maybe because I didn't pull the computer, not sure. When you pull the auto shifter assembly, there will be 4 or so harnesses left laying there. On one harness (on the drivers side, I think it was the biggest connector on that side) I connected pin # 2 (green) to pine #5 (counting sraight accross, left to right) brown or black, not sure, its a ground I think, and the other harness I had to modify was also on the drivers side of the shifter assembly, its two bigger guage wires, I just connected them together. These two harnesses control the kill starter (makes sure car is not in gear when you start it) and the other makes it so you can take your keys out of the ignition, basically, I tricked the computer into thinking it is always in park.
or you can take the car to racing integration and have colin do it real quick, he did mine.
___________________
TRD_Tc
May 30, 2005 05:24 PM
Jubee
Dec 31, 2003 08:53 AM
Patrick
Feb 26, 2003 06:27 AM
cosmo459sx
Feb 16, 2003 09:24 PM
Riot
Feb 28, 2002 01:30 AM
