Boosted A/F, what's your opinion?
Old Apr 6, 2005 | 09:48 AM
  #21 (permalink)
mtber's Avatar
This is a lamence explanation, but it will do the job.
There are tons and tons of information on tuning theory out there, if you're interested in learning it all. Buy some books & read
Air Fuel Mixture is obviously the mixture of air (oxygen) to fuel.
25-30% of air/fuel mixture energy actually becomes "work" aka thrust.
The remaining 70-75% becomes exhaust. Ignition timing & A/F ratio are both used to control the heat which an engine produces. Running a richer air fuel mixture on a boosted motor, helps absorb the heat which is produced. I.E. Charge density increases, more heat is generated etc.
Concerning enrichment safety:
In most cases the power differences between 12.5:1 and 11.8:1 air fuel mixture are usually very little. Hence, most tuners tune f/i street cars at 11.8:1-12.0:1 a/f at WOT depending on the spec of the setup i.e. compression ratio etc. Some additional factors to account for are temperature, altitude & humidity all affect air fuel ratio. Most engine management systems including Hondata do not have correction factor for different intake temperatures, altitude etc. Hence, you tune your car when its 80-90 degrees outside and target a certain a/f ratio. When it is colder outside (50-60 degrees) you can expect your air fuel ratio to change. For this reason, it is a good idea to tune very conservatively on a street setup.
Other important topics to consider is ignition timing, knock, MBT and so on.
Old Apr 7, 2005 | 11:19 AM
  #22 (permalink)
NChatch's Avatar
i stepped on my weiner!
other than combustion reasons, fuel is the sole factor and is neccesary for COOLING REASONS, fuel is used to cool the motor, and make sure that heat is drawn from the motor upon exhaust expulsion. very simply put.
the rings in our cars need this extra amount of fuel to quench them and cool them and the internal components of the engine.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 7, 2005 | 11:45 AM
  #23 (permalink)
qitstrn's Avatar
Can you spot me 20 cars?
Originally Posted by 60-1EK
I will sit back for a while and have some of the other people that tune cars explain it.
So how long untill you enlighten us with your knowledge? We are all waiting please share.
civicjunkie
Feb 23, 2003 10:12 AM
mpbiv
41
Aug 28, 2002 10:08 AM
