turboing the SOHC
Old Mar 15, 2005 | 06:35 PM
mikebish86's Avatar
or check teamrice.org, and look at that guys blurbo'd SOHC, runs twelves w/ stock block and whatnot.
Old Mar 15, 2005 | 06:50 PM
kwikdelsol93's Avatar
Right now I'm just going off what tony's car makes. www.slammdsol.com He puts out around 240 to the wheels. dont quote me on that though.
Old Mar 16, 2005 | 06:06 PM
Slammd Sol's Avatar
Originally Posted by mikebish86
yeh defs. even tho they have low 9.5:1 compression, they are still very weak. ive read alot of my honda/acura books and they say the only d-series rods that can actually handle over 200+hp w/ large amounts of boost are the d16a/zc rods....which you can get a whole block at cophers for $99. then take em somewhere to get cleaned up...shotpeend etc. and dont spend shit loads of money on aftermarket pistons/rods.
You're not accurate at all...
D15b's have a 9.2:1 C/R. They also have nearly the same exact rods as the D16z6, only difference is they have utilize a smaller journal bearing on the crankshaft. And being that they are 1.5's, they have a 3mm shorter stroke, which gives them a better a R/S ratio then all other D series engines and most other B series engines (minus the B17a). Thus, techinally speaking, a d15b would be better for boost and high revs then all other D series engines.
D15b rods on the left and D16z6 rods on the right
Old Mar 17, 2005 | 06:23 AM
Hybrid_eg's Avatar
i like the blue ones
Research is great, isn't it Slammed Sol? GOOD INFO
Shut yo ass up nugguh..
ReginaVagina
Old Mar 17, 2005 | 01:52 PM
mikebish86's Avatar
ooo man sorry i dont research my d-series stuff. but if you had any idea what i was talking about then you would realize i said the D16A1 or 3, 9.5:1 or ZC, 9.6:1(not the D16z6)...which is a DOHC dseries motors....and even if the stroke might be shorter by 3mm, and rev slower. But they defs are stronger than the D15b, and the D16z6 garbage motors. just my .02, and if you want you can take your precious time and come back w/ better research that defeats mine, b/c i have much better things to do w/ my life.
Old Mar 17, 2005 | 02:47 PM
Slammd Sol's Avatar
WTF? I was meerly correcting you. Not trying to prove how big my E-Cawk was..
And if im reading what you wrote right, you said the only engines that could handle 200+hp were the d16a's.. which is obviosuly wrong, as I know multiple stock block Z6's in the 230-250whp range. And what exactly makes the D16A1 or A3 a stronger better motor then a d15b or z6? I sure as hell know the D15b has a better R/S ratio and has the same rods..
Old Mar 17, 2005 | 06:32 PM
  #17 (permalink)
This kinda sucks no one is telling me what kinda turbo kit to get lol. But thanks for the back up Tony.
Old Mar 17, 2005 | 09:23 PM
  #18 (permalink)
Hybrid_eg's Avatar
PM Cronic. He's the O.G. SOHC turbo man. Also shoot one to Trip. Utilize the search function for SOHC VTEC turbo while you're at it. Remember, it all comes down to what YOU want, not what sounds good to somone else.
ReginaVagina
Old Mar 18, 2005 | 04:36 AM
  #19 (permalink)
Slammd Sol's Avatar
www.turbod16.com
Everything you need to know is in the forums and the FAQ's.
Old Mar 19, 2005 | 11:59 PM
  #20 (permalink)
What about a T25 turbo? Since im kinda new at this i should probablly start out smaller power right? Well so far I found my intercooler lol.
