Upgrading the Turbo on my Greddy Kit
Old Mar 10, 2005 | 02:07 PM
TRD_Tc's Avatar
Using The Force Of N/A
Default Upgrading the Turbo on my Greddy Kit
Ok I have some extra money so I'm planning on upgrading the Turbo on my Greddy Kit for the Ls. My goals are pretty simple. I want to run about 12 psi maybe 14. I use my Ls as my daily driver so I'm not looking to over do it that much. I've already built my bottom end with wiesco pistons and eagle rods so I'm set to reach my goal. What turbo would suite my kit best without overhauling everything. Also, would I be able to keep my current manifold or would I need to switch it along with what wastegate? Thanks.
Old Mar 10, 2005 | 02:24 PM
mtber's Avatar
Get rid of your manifold, downpipe assembly etc.
Buy a decent manifold setup & d/p setup i.e. inlinepro, spoolinperf, along with a t3/to4e turbine such as a garett 57 trim .63 ar turbine or a precision sc61 depending on whp goals etc.
You may need bigger injectors too
Old Mar 10, 2005 | 04:13 PM
NChatch's Avatar
i stepped on my weiner!
yeah the greddy kit was a totaly sealed unit so to speak, there isnt much to upgrades for it. it ises mitsubishi turbos i believe, and the ones that come inthe kit are about as good as they get, plus the downpipe elbow is kind of a funky design, and you need something with an external wastegate
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 10, 2005 | 06:03 PM
TRD_Tc's Avatar
yeah, the only thing I hate about the Greddy Turbo is the fact that it takes too long to spool up (even once it does its pretty sad).
Old Mar 10, 2005 | 07:28 PM
JJFreshyZC's Avatar
TR Shop Mod
I was seeing boost around 3500-4K rpm with that kit.
I agree with just upgrading the turbo, 20G or another Mitsubishi/Greddy spec turbo. Get rid of that downpipe and get a custom 3" made. That is if you plan to use it as a daily driver, if not then go all out with something with more potential.
Old Mar 11, 2005 | 01:36 AM
TRD_Tc's Avatar
see that's what I'm seeing too (boost at 3500-4k rpm). it just feels like the car is lagging and wanting more. once it hits the whole 7-9 psi that's it. i want to turn up the boost on this thing to run atleast 10-14 psi all the time. could anyone tell me how to do that with the stupid internal wastegate?
Old Mar 11, 2005 | 05:25 AM
DAMPACHI's Avatar
Paul @ LHT Performance
get a boost controller.
Old Mar 11, 2005 | 09:56 AM
JJFreshyZC's Avatar
TR Shop Mod
Yes, get a boost controller and you can crank it up. See what that does for you and go from there. Did you ever get a bigger downpipe? What exhaust you running also?
Old Mar 11, 2005 | 01:09 PM
TRD_Tc's Avatar
exhaust is still in the works....I'm trying to get this turbo/mani part done 1st so I don't waste money on two downpipes.
