engine problems
Old Mar 9, 2005 | 10:08 PM
civicsi2g813's Avatar
TR Balla Donor Supreme
Originally Posted by Miles
ok, went back outside, started it up, revved it a few times, no noise... nothing out of the ordinary... i'm mystified.
Just a quick question.......was the engine warm when you reved it up? if not let it warm up and try again. Also rev it up and put your hand on the valve cover *dont burn urself but see if you feel any vibration
fyi sounded like you were misfiring possibly, i know my valves were super tight and caused a misfire and my shit was shaking like a 4 dolla hoe on quarter night
drinkin hatorade since 1980
Old Mar 10, 2005 | 09:35 AM
N1_STYLEz's Avatar
SAVE THE SOHC's
was it idling REALLY low? i think my O2 sensor is bad b/c it doesnt like to start up when it sits for a while(btw does that sound like thats the problem?) and when i do get it started up it idles really low... after i let it sit for a while and start driving it it will buck back and forth also and then i hold the pedal down and it finally pulls out of it... see what happens if you do that... my car drives fine after that... as far as the sound goes mine makes the same sound right before it dies but i always attributed that to the RPM's being extremly low or something
-Josh
'91 EF Civic Hatch(daily)
'93 GSX (in the making)
Originally Posted by 94lsTEG
Originally Posted by geoff
either way he still stomped my ass
ummm you own a civic...get used to it!
Old Mar 10, 2005 | 10:10 AM
aka5000's Avatar
I would start with what you know is wrong. replace the o2 sensor and go on from there. just my .02
Old Mar 10, 2005 | 12:47 PM
Miles's Avatar
It's a wooden pickle.
no sense in replacing the o2 sensor if a rod is poking through my block
Old Mar 10, 2005 | 01:24 PM
Derka's Avatar
my car has bucked before because of the idle air control valve, and you said yours is bad, was it bucking just under light throttle? and for the noise, no fucking clue
1998 crv daily beater
Old Mar 10, 2005 | 02:04 PM
Miles's Avatar
the idle air control valve on my car has completely checked out... it's not doing the stupid revving idle thing, but it will die at stop lights and such, start idling at like 400 rpm, etc. and yes, all of this was at partial throttle around 2000 rpms.
Old Mar 10, 2005 | 02:41 PM
  #17 (permalink)
Jaso0on's Avatar
Is now ballin!
Change IACV, TPS, and o2 sensor. I've had the bucking shit before after a nitrous backfire, broke the screen in the IACV, are you spraying? Get those changed and let us know.
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Mar 10, 2005 | 03:10 PM
  #18 (permalink)
Miles's Avatar
i know what's causing the motor to stutter and buck and such, that wasn't really the issue, i was more worried about the noise than anything.
Old Mar 10, 2005 | 03:18 PM
  #19 (permalink)
Cold_Beer's Avatar
Rockin' 4 more Cylinders
fuck it......if it isnt doing it anymore
RIP Robert Kolp aka 00ek 4/07
_Jake D
Slotegé
Mazda Tech
11
Apr 10, 2004 07:37 AM
Jordan Y.
Mar 26, 2004 04:48 PM
defekt
Aug 28, 2003 06:17 AM
Scott
Nov 7, 2002 07:33 AM
