A/C not working?
Old Feb 28, 2005 | 07:06 PM
I-NEED-VTEC's Avatar
I have NO vtec!!!
Question A/C not working?
i just put in a new motor in my g/f's car and the a/c dosent work, i have no idea whats causing this so any help is appreciated,and also the check engine light came on a little after i put the new motor in any ideas on that?
Old Feb 28, 2005 | 10:22 PM
blurboEK's Avatar
proud father ;D
Did the a/c work before the motor swap? Did you re-charge the system? Is it holding a charge. Are you using your old a/c compressor or the one that came with the swap? Is the clutch engaging (on the compressor)? Answering these questions will help diagnose your problem.
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
Old Mar 1, 2005 | 11:48 AM
I have NO vtec!!!
it was working before i swapped motors and i am using the original setup nothing was wrong before swap was done.also the lights dont even come on at night,the ones for the a/c controls.i have no clue whats wrong.i might have put the belts on wrong?,but every thing else is fine other than that,any ideas?thanks-keith
Old Mar 1, 2005 | 12:18 PM
EludeR's Avatar
Originally Posted by Cronic
Sounds like the power is missing somewhere.
Agreed
Old Mar 1, 2005 | 02:40 PM
I have NO vtec!!!
i think you are right,but,i hooked up every plug back to the right one.could it be a fuse or something else?its the original harness and the a/c was working before the swap so.....i have no idea what the hell it is.thanks-keith
Old Mar 1, 2005 | 04:03 PM
blurboEK's Avatar
proud father ;D
first check and make sure there are no blown fuses. Second, turn the car to acc. unplug the a/c plug from the compressor and turn the a/c on. Check with a volt meter to see if you're getting power to your compressor. Your a/c harness should be part of the body harness and should not matter that a new motor was put into the car. I'm guessing a fuse if the a/c light doesn't come on.. keep us posted.
-Mike
Old Mar 1, 2005 | 04:08 PM
Blake's Avatar
come on she doesnt need A/C it robs HP
haha
JESUS DRIVES A HONDA
Old Mar 3, 2005 | 08:29 AM
I have NO vtec!!!
yeah im gonna try tonight to see if its a fuse,which it prob. is considering that the lights for the controls dont come on.but ill try tonght.thanks-keith
stehigs321
Jul 22, 2003 08:58 AM
dan
Nissan/Infiniti Tech
Jul 6, 2002 08:53 AM
