Clutch problem on 92 accord
Old Feb 25, 2005 | 07:58 PM
ScOoByDoOd007's Avatar
-- www.813Motoring.net --
Default Clutch problem on 92 accord
hey guys i just bought a 92 accord 4dr.......ok when i push downt he clutch the clutch just sticks to the ground dont know what it is.....ppl we bought it form said it needs new clutch but it wont even come back up i dont know if clutch is bad or what i dont think soo cuz it would still have some resistance in the pedal wouldnt it?? soo if anyone has a clue lmk i need to fix it asap
Old Feb 25, 2005 | 11:30 PM
LS1Fever's Avatar
i would just be safe then sorry and put a new clutch in it.
Old Feb 26, 2005 | 12:58 AM
lowoctane's Avatar
Professional Dumbass
how's the fluid level?..have you tried bleading the lines just to see if there is a difference?
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Feb 26, 2005 | 07:26 PM
im going to check on the fluid stuff tonight and maybe see if that works
Old Feb 27, 2005 | 06:50 PM
alri0085's Avatar
Scuderia ALRI
Don't change the clutch. The problem is the clutch cylinder, you may need a new one, or you may need to bleed it. I had the same problem on a 92 accord, so I know all about it.
Old Feb 27, 2005 | 07:09 PM
ok how do i bleed the system?? if someone lives in tampa off of bruce b downs and would like to show me how to fix this problem ur more than welcome...
Old Feb 27, 2005 | 07:11 PM
sloaccord's Avatar
bad ass fonzie
fifty bucks says your clutch master/slave cylinder went bad. i bet the clutch itself is fine.
check underneath the dash, up where the clutch pedal rod goes into the firewall. there may be some fluid there, or on the engine bay side of the firewall. then the master cylinder is bad;
the slave cylinder can go bad too- it's in front of the tranny. check for fluid there too.
both are a simple repair.
member no. 191
Old Feb 27, 2005 | 07:13 PM
sloaccord's Avatar
bad ass fonzie
to bleed the system, though i dont know why you're doing it if you havent diagnosed the problem-
on the slave cylinder, there is a small nipple pointing towards the fans that you can stick a wrench onto. it should be like 6 or 8 mm's- real small. thats the bleed valve.
member no. 191
Old Mar 1, 2005 | 05:52 PM
fixed it thanks for the info guys.......i guess it just needed to be bleeded dont think there was an air bubble tho the fluid was pretty nasty and dirty....
Old Mar 1, 2005 | 09:48 PM
lowoctane's Avatar
woohoo score, good to hear that!..thank goodness it was something simple.
Slash
Sep 21, 2003 02:03 PM
BlackZ28
9
Sep 19, 2003 04:57 PM
Akkord29
Aug 30, 2003 10:21 AM
RazziGT
Jun 6, 2003 01:31 PM
CXHatchback
Dec 13, 2001 09:25 AM
