Swap info needed....knowledgable please help
Old Feb 15, 2005 | 05:57 PM
tampamax's Avatar
Default Swap info needed....knowledgable please help
I need to know if a 3.2 type S motor can be bolted up(mounts and mating the tranny) in a 94 Legend? Or if this would be to much trouble is there a 3.5 bottom end that the Legends heads would bolt right up to? This is for a 94 Legend w/ auto.
You don't like it? So sue me. Don't take me seriously though.
Old Feb 15, 2005 | 08:41 PM
KJ's Avatar
KJ
bored at work
What is the engine code on the Legend?
Old Feb 16, 2005 | 07:45 AM
tampamax's Avatar
Not sure. I know that the sedans have a 7 for the 6th place in the vin number for some kind of engine designation, but other than that i don't know anything else. Could you help break it down as to what the importance of finding the engine may be?
Old Feb 16, 2005 | 08:27 AM
Jake's Avatar
dýsfuňctiønal
It should be posted on the block somewhere?
FLeuro
TheCommision
Old Feb 16, 2005 | 09:30 AM
tampamax's Avatar
Thanks, but i don't exactly have the block in front of me. There were only 3 versions of this Legend. The sedan, L, and LS. This is the LS i believe. I'm not sure but i think all 3 models had the same engine. If you are trying to figure out if it had the Type II motor in there i can tell you its did not.
Old Feb 16, 2005 | 03:55 PM
SEEKERone's Avatar
Trialed for Treason
no...will not bolt up...not even close
94 legend has engine placement front to back... sort of like rear drive car
3.2 type S were mounted transversly(side to side)
Liar, you couldn't cut me deeper with a knife if you tried
Old Feb 16, 2005 | 04:43 PM
tampamax's Avatar
I am aware of that. But do you know where the mounts are on each block to make that determination, or are you just suggesting that becasue you've noticed the engines sit under the hood in different positions? In other word if i were to sit a bare 94 legend block and a bare 2001 type s block side by side would you be able to know which one is which? The question still remains will the pieces(newer engine older tranny) bolt up to each other, and would the newer engine drop in(in the same position as the old engine) without a major hassle?
Geisert
Apr 8, 2002 06:16 AM
advan7
Dec 29, 2001 11:20 AM
