auto - 5 speed conversion
I plan on converting my 93 accord to a 5 speed. It's got the stock motor (F22A1). I was thinking of using a H22 5 speed tranny, what i really need is someone to tell me every part that i need to get the conversion done and other info if possible. Thanks alot, Ian
this is the basic parts list for a G3 integra auto to manual, but it should get you pointed towards the right place!
1. The trans.
2. Linkage rod assembly
3. Manual trans. console
4. Shifter and knob
5. Manual ECU
6. Pedal assembly
7. Clutch slave and master cylinders
8. Clutch fluid container
9. Clutch hard lines and hoses
10. Flywheel and bolts
11. Clutch set with alignment tool and throw out bearing.
12. Manual intermediate shaft
13. Rear trans. mount bracket for manual trans.
14. Front trans. mount bracket for manual trans.
15. After re welding the bracket on chassis, a top tran. mount for manual trans.
16. Starter for manual trans.
good luck!
1. The trans.
4. Shifter and knob
5. Manual ECU
6. Pedal assembly
good luck!
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
meows meows
Originally posted by Cronic
I'll never understand why people do this....
It's so much simpler, and nearly as cheap to buy a manual version of the car.
meows meows
meows meows
Originally posted by Sabotage
he speaks the truth.......i'd rather just buy another car!....i can see how one can get attatched to thier current car though and not want to get another one.
