smell burning oil when vtec hit ???
might be your rings, if your already burning oil then your just going to burn more during vtec, if you have a sohc you might want to think about a swapping to a b series
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Guest
Posts: n/a
Originally posted by zcnitroso
yeap oil level is low, it burning about 1/2 quart of oil every week,, what seal you talking about ???
but if you oil is low then i am leaning towards something like rings... do a compression and leak down test...
-Keith
p.s. this is the seal you are looking for...
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
you are missing my point... if you have too much oil, then when your oil pump is running at peak (high RPM's under load) your oil pressure would be high enough so that it could push past some seals in the motor (like valve seals) and burn in the cylinders... hence smelling oil...
-Keith
-Keith
anyway it's more than likely the rings. like the other guy said, if it's already burnin a lil oil, it'll burn alot more under the higher rpm and strain when vtec kicks in
and that's one funny lookin seal! lmao
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
Originally posted by Cronic
You just answered your own question. If you're burning 1/2 qt every week. That's what you're smelling.
Think people! :bbb:
Think people! :bbb:
I warning to all of the smart asses. If you're going to be condesending, please add something that will help with the posted problem. If not I will be locking these posts.
Thank you.
Thank you.
Dont be a jackass, everyone is having fun here and nobody and no disrespect here. This is a forum, not the Christian Academy were you have to seat tight and look straight. Everyone is allow to write what they want, of course, keeping in mind, we respect the others. Why dont you go and look for the ones that, dont show this. . .
Thank you
I miss tampa fl
I miss tampa fl
Guest
Posts: n/a
Thank you
Thank you
but, to answer this for you... "Everyone is allow to write what they want, of course, keeping in mind, we respect the others" IF everyone could respect others, and understand that we are all joking all the time then maybe that could work... but, even if you know what someone is joking it can still hender someone getting an answer that they need in a timely fashon...
-Keith
piston rings and/or valve guides/seals...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
