Engine Warmup Time
Old Dec 7, 2004 | 07:15 AM
lead's Avatar
I'm Awesome
I don't live on campus anymore so i don't have that luxury
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Dec 7, 2004 | 07:43 AM
shadowboy's Avatar
insert witty retort here
i won't be either, come may. as i graduate then.
of course, at that point it is questionable whether i will be living in tampa long.
Shawn
The answer to your question is sqrt(pi)
Old Dec 7, 2004 | 09:14 AM
99B16Si's Avatar
on a stock motor such as yours its not really gonna make as huge of difference how warm the car is compared to a built motor(within reason of course). is more the oil temp you should be concerned about instead of the coolant but unfortunately a factory honda does not come equipped with one. although coolant and oil temp are realted they are not the same by any means. when the motor is not warmed up all the way youll see slightly higher oil pressure which isnt bad unless the car is ice cold and youre seeing 120+psi of oil pressure. when the motor is cold, the oil is thicker, thicker oil will have a harder time lubricating tighter clearance areas, which is ok at lower rpms but at higher rpms where the extra lubrication is needed its not the best idea to go there. the only bad thing thatll happen if your coolant is below 160F is vtec will not work.
now if your talking about a boosted motor with forged internals, the warm up period is lot more critical because the internals need time to expand, high rpms on a cold forged internal motor can cause cylinder and piston damage if done repeatedly. and also the extra oil pressure going to the turbo on a cold start isnt good for the seals if your start pushing it and hitting full boost.
hope that helps
Old Dec 7, 2004 | 12:13 PM
Sabotage's Avatar
slash
mine takes a while to warm up sometimes too, and my needle usually only goes to 1/4 - 1/3 of the way up....depends on the weather...if its hot outside, it doesnt take as long....but if its a cool night and im driving home from work (7miles), sometimes my car hasnt reached normal op temp by the time ive gotten home....i know my thermostat works cuz ive bleed my coolant before and seen it cycle, so i just havent worried about it.
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Dec 8, 2004 | 01:13 PM
zcnitroso's Avatar
My B16a2 takes forever to warm-up, 10-15 min. sound about right to me. I had a CRX and it was worst than this one. I dont think is nothing wrong with that.
I miss tampa fl
Old Dec 8, 2004 | 01:19 PM
  #17 (permalink)
slovvcrx's Avatar
ZC answer pms please
Old Dec 8, 2004 | 06:42 PM
  #18 (permalink)
89crxsir's Avatar
my crx takes like 2 min to warm up 5 at the most......strange?!
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
