Coil-Over Install
Old Nov 30, 2004 | 06:29 PM
JDM-Civic-Coupe's Avatar
USAF
Question Coil-Over Install
Hi, my sister just recieved some coilovers she ordered from ebay. I was wondering if the 350p coilovers(2 of them) go in back cause there is less wait. they are also thinner than the 450p coilovers. and any more pointers on bushings or hex screws would be appreciated. thanks for your help.
-Chris
USAF
Old Nov 30, 2004 | 07:08 PM
lead's Avatar
I'm Awesome
350 front, 450 back
they actually are not that bad mine lasted for a year before they were no longer stiff
EDIT: to make these fit your going to want to take off the top dust cover on the strut, unless it fits with it on there, but i don't believe it does. but make sure you leave the rubber stoppers on there for when you bottom out.
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Nov 30, 2004 | 07:29 PM
mtber's Avatar
Check out:
http://www.c-speedracing.com/howto/c...r/coilover.php
It will help you w/ the basics.
Old Nov 30, 2004 | 07:39 PM
lead's Avatar
I'm Awesome
lol extreme basics, that is just how to remove the struts, what your going to do is take apart the strut once you get the stock springs off it, then sit the coil overs on it, its not difficult. 2 hours max
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Old Dec 1, 2004 | 07:39 AM
USAF
when i take the struts, if i have lowering springs on it all ready, do i need spring compressors?? also, where are the rubber stopper? and do i have to shave the dust thing or is there a way to take it completely off? thanks again.
-Chris
USAF
Old Dec 1, 2004 | 09:29 AM
lead's Avatar
I'm Awesome
just pull up, it depends on the drop if the springs and tentioned while on there it's your life your playing with... i would compress them. the nut will do some serious damage if it shoots off
and the dust cover pulls off with a little bit of persuasion, rubber stoppers are found inside of it
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Old Dec 1, 2004 | 10:19 AM
Punkinterviews's Avatar
Chavez Motorsports
You shouldnt need a spring compressor....I never use one. But then again it is up to you and usually lowering springs never need a compressor. Good luck and if you need some help just PM me.
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Dec 1, 2004 | 10:31 AM
lead's Avatar
I'm Awesome
how did you avoid having the bolt go through your jaw if you never used one?? and also how did you find the bolt?
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Old Dec 1, 2004 | 11:12 AM
Bserieskllr's Avatar
i never used a spring compressor either what i did was layed it on its side in the grass and the loosened it, dosent shoot of more like pops off.
92 240sx Vert-Drift car-CA Powa!
91 Civic Si-Minty Fresh-Boosted B20/Vtec
01 IS300-DD beater-2JZ no shit
Old Dec 1, 2004 | 11:22 AM
05 TypeS DC5's Avatar
07 e92
i've never had to use a spring compressor for lowering springs i just put a steelie on top and loosened the nut...
