THE street tire VS SLICK debate thread...
Originally posted by InsaneCivicSedan
No, actually it isnt... Some classes only allow DOT legal street tires (drag radials) and there are some classes for slicks only...
Some cars dont make enough power to spin slicks, so they use drag radials, some cars make just enough power, to use either or and not really make a big difference... My car for example, has plenty of power to run on slicks, but also lacks just enough, that I can still cut some pretty decent times on drag radials, without breaking as much shit... Then you have some cars, that just make gobs of power, that cant efficiently put it to the ground on a radial tire... that is where the slick comes into play, and from there, its all about sizing...
Originally Posted by Zate
i still stand by the fact that 75% of 16-23 year olds are dropped babies.
Originally Posted by Boosted240
Mustangs are the hondas of the domestic cars. The drivers are always doing ricer revs and just like hondas, about the only place you cant buy parts for them is at 7-11.
Classes for imports are much different... For example, the Turbo4 class has 2 different variations, one of which is for slick tire street cars, and the other is strictly for drag radial street cars... All cars must be street trim (legal to drive on the street), and the only difference between the 2 classes are the tires....
http://www.fastestfwdstreetcars.com/index.htm
Check out that website if you would like to know more about what Im talking about, and also stop by and read the RULES section... This doesnt really go into the details of the Turbo4 street tire class, but it will give you the general idea.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
I was wondering if that was an import thing right after i replyed. that explains all that.
As a few peopl have said on here its NOT cut and dry, i myself have both slicks and drag radials, i always wanted to see how well my car did on "street tires" the way i would drive it around town, but was too busy with running my car on slicks getting my ETs where i wanted them, that i forgot about them and didnt bother. but i have seen some new light in a sense of pride in being able to run low ETs on street tires, and its kinda cool.
yeah sure some cars can run 11s on slick but can i do it on anything else, i dont know but im gonna give it a try
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
it depends on the car i guess i prefer street tires/ drag radials i drive around all the time on 555R's and since my car is a street car i like knowing that it runs the same at the strip as it does on the street
John
John
John
John
Originally posted by Drace1963
I'm sorry, but it DOES SEEM pretty cut and dry to me since all I run is slicks, and I don't drive my car on the street. For the people that do drive there cars on the street, I guess it ISN'T CUT AND DRY. My bad. I have always believed in trying to go as fast as I could so to me that means at the track ya run slicks because they are going to hook up the best. I'n my case anyway.
FWD cars have serious issues with traction on higher hp cars and slicks are the only option to get all the power to the ground. I refuse to run stupid sized drag radials on my car.
im a fan of both. i use slicks to find out whats the best time i canget out of my car. as far as a street tire i always do a pas on street tires before i run on my slicks. every time i run i get asked what do you run. i always reply with what i run on street tires because there is no way your gonna hook up on the street, the way you do at the track. i use both im a fan of both but if i had to pick one i would lean towards the street side
tamparacing.com
Originally posted by mtber
Then again running street tires at the track at 18 psi isnt really "real world"......
so im def. going to go with the street tires over slicks, they also give ur car more of that "im going to spin through 4th" look, and when ur on slicks, ppl think ur cars no joke..
Guest
Posts: n/a
I won't run slicks until Im breaking 400whp. I just, personally, don't see the need for them. Sure, I may spin until redline in 2nd gear... but that's fine. I won't be picking up that much more with slicks. Im not out to see the best time I can do. Im out to see an avg of what I can do. Im far away from my goal of 450whp. So I have a lot of tinkering to do before I get any slicks.
