ls/vtec... think this setup will last?
sounds like a nice setup, I would've used stock Honda rings though. With the block decked and the head shaved, you're looking at pretty high compression, I'd say from 11:5-12:0:1. Who did the pnp, that makes a big difference. With some poor craftsmanship, the head would be better untouched.
The most overused word to describe an import: CLEAN. Every f****** car is so CLEAN.
Trash the JE rings for OEM honda rings.
honda valve seats are very small in relation to v8 heads. 5 angle valve jobs are used on larger valve seats and would be very hard to due and just over kill on a honda. a quality 3 angle is ideal but i know of some who use 4 angle with good sucess.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
I think thats a good setup forget the je rings what ecu are u using help me out with my project. get the itr oil pump and water pump though it will be better for performance. help out the engine better. let me know whut ecu u r using though thanx alot nice work good luck.
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
08 Acura TSX_ 6mt
jason... when are you finally gonna make up your mind whether it be the stang, a hatch, a formula??? seriously dude. sounds like a .... sound set-up good luck with w/e you are going to do next
TR's drive my car more than 2500 miles in less than a month crew member #01
