Exesive exaust smoke from the DA???help
Old Aug 18, 2004 | 05:31 PM
DA92driver's Avatar
Default Exesive exaust smoke from the DA???help
ok,its a 92 integra Rs,sometimes sitting at idle theres more smoke than normal coming from the tail pipe,(whitish),and from a stop and high rpms its smoks alot,when i race im considered the mosquito killer .what the hell could this be,and how much would it be to fix it,i have access to a shop just need to know how to fix this damn thing..thanks in advance
Old Aug 18, 2004 | 05:50 PM
Josh's Avatar
Dr. Doom
whitish smoke could be either oil or coolant, i would check your h/g first tho.
Old Aug 18, 2004 | 06:20 PM
DA92driver's Avatar
what would i look for when doing that.? i mean like water leaking? oil?,cuz on the block is quite a bit of oil..
Old Aug 18, 2004 | 06:22 PM
DA92driver's Avatar
AND,the motor has somewhere b/t 100k and 150k miles on it....
Old Aug 18, 2004 | 06:28 PM
Josh's Avatar
Dr. Doom
do a compression test and/or a leakdown test, this will tell you.
Old Aug 19, 2004 | 07:20 AM
Jay's Avatar
Jay
Janky
hes talking about oil or coolant leeking into the cylinders you more than likley have some bad rings or valve stem seals.
or if it is coolant a bad head gasket. you can pull the plugs and look down the holes if you have shiny pistons could be coolant.
but yea i would start with the compression test and leak down.
-Jay
Aim: o JankyJ o
http://jankycrew.com
Old Aug 19, 2004 | 06:46 PM
DA92driver's Avatar
alright thanks alot,ill have it in our shop tomorw ill let you know how it goes...
