help
Actually, your car should run a little stronger at the bottom end w/out a headerback exhaust system.
Its going to run a little choppy w/out an exhaust system.
But its not going to fall on its face...
Do all the things I recommended & check for vacume leaks if your idle is fluctuating too
since its a jdm it has a ajustable tps but i dont know if thats what it is, also obd2 has some kinda evaporated system or something that has to do with fuel or something but the b16 doesnt have anywhere to hook up
Run the correct ecu, resolve your codes & go from there.
