help
What ecu are you running ?
What I am really trying to figure out is, are you running a 1.8L program on your STOCK 1.6L motor ?
Hence you are probably getting too much fuel
Are both ecu's acting the same ?
It may not be your ecu.
A p72 ecu is a gsr ecu, I dont recommend running it on a motor without secondary butterflys b/c you will throw a code etc...
Throw your lightshow autometer guage into the garbage or sell it because it wont really tell you anything.
The big fat white wire in your engine harness under the pass side kick panel is the source for 02 readings.
I believe since your running an ecu that uses 1 02 sensor you have to tap directly into the 02 sensor area of your harness to get an accurate voltage output reading to your autometer guage.
Regardless autometer guages don't tell you anything that a voltmeter wouldnt tell you
You only have 1 vtec
No secondary vtec
Check your plugs, ignition timing etc..
Check your fuel supply via using a fuel pressure guage.
Maybe change out your fuel filter if its old, heck its only $8 from honda.
Remember it's a b16, it will be slugish off the line at low rpms, especially on the wrong ecu.
No secondary vtec
