header pipe metal??
Old Aug 15, 2004 | 07:06 PM
kender's Avatar
gadget man
Default header pipe metal??
I know its not actually h/a tech but its for a project that will BOOST h/a vehicles to a new level.
does anyone know where to go to get elbows and straight pipe that can be used for an exhaust manifold, I need sizes from stock exhaust port to 40mm for wastegate to 3" for down pipe. thanks
U.S.S.A Crew Member #001
Old Aug 15, 2004 | 07:22 PM
kender's Avatar
gadget man
I am welding a turbo manifold for a b16 and basically the wastegate dump tube and the down pipe, I don't mind stainless steel except that it expands too much when heated and I will need to brace the mani since the turbo setup I will be using will be to heavy for just the mani alone to hold.
Old Aug 15, 2004 | 08:41 PM
Josh's Avatar
Dr. Doom
what the hell setup are you running that's too heavy for the mani?
Old Aug 16, 2004 | 03:38 PM
kender's Avatar
gadget man
the setup is a twin turbo, and no its not like any other setup you have seen, well ok maybe 1 or 2 have seen something similar, but with all the research I have done and a stack of import performance mags that would reach the jolly green giants nuts, I have not seen or heard of anything like it. I have tested the theory on a bench test using pressure gauges and compressed air and it all works out so now it is time to fab up the stuff I need. thats why I need to know where to go to get the simple bends and straight stock that home depot doesn't have, I will also need flat sheet for the flanges. thanks
Old Aug 16, 2004 | 05:23 PM
Josh's Avatar
Dr. Doom
what motor is this on?
Old Aug 16, 2004 | 06:03 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
I suggest you save the hassle and buy the flanges... 1/4" sheet is a BITCH to cut......
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Aug 16, 2004 | 07:19 PM
kender's Avatar
gadget man
this is on a b16, well its getting fabbed on a b16 but when it is time to fire up an engine and run it on a car it will be whatever I can get my hands on that runs and has a d or b series motor.
for the flanges I would love to buy them but they are expensive as hell, if you know af a place for some decent quality flanges for a little price tag hook me up, otherwise it'll be me, the jigsaw, and a gallon of cutting oil
I will need 3 t3 exhaust mani flanges, 3 t3 5 bolt downpipe flanges, 5 38 or 40mm tial type wastegate flanges, and a b series exhaust mani flange, not all of these are used on the set up but I need a few extras just incase the welding doesn't go as planned
