header pipe metal??
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
not worth it??? only if running a conventional twin turbo, but with my setup where you would normally see 5psi between 2-3k rpms you will see 10psi, at whatever rpm you see a given boost level this setup will double that psi. I have done the bench tests and talked to some engineers, plus my own knowledge of pneumatics, and my idea has proven to work so far. this will be fabbed up and put on a running engine as soon as time and budget allow.
Originally posted by Sunrise City Rider
http://www.honda-tech.com/zerothread?id=886024
Just do it man then show it off...Don't post your weird ideas on here and expect support...You say you speak with engineers well ask them what metal to use and what not...You are asking the wrong questions here...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
well I guess we know that you could give a shit about anyone else but yourself.
and at what point in my question at the top of the thread did I ask what type of metal????? I asked WHERE to get it.
Don't even waste your time trying to make something like this. It takes time & experience to make it look nice & work properly, not to mentsion make it durable.
Contact lovefab: http://www.lovefab.com/
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
I would like to get a good plasma though, probably about the same time I can afford a tig welder.
